Kenwood double din multimedia headunit in 308
Messagede Gentry » Mer 27 Aoû 08 22:44
This is my latest project for a customer. A Kenwood DNX8220BT headunit with special interface and mounting set.
Boardcomputer functions can be set through the steeringwheelremote and a special interface
Gentry
Re: Kenwood dubble din multimedia headunit in 308
Messagede landsraad59 » Jeu 28 Aoû 08 20:11
Salut, Ton projet m'intéresse. Pourrait tu me donner la référence de la pièce qui sert de cache de couleur "Warm silver" ? celle qui fait le tour de l'autoradio. Pourrait tu me donner egalement le nom de l'interface pour conserver les commandes au volant ?
Que dis tu du Kenwood DNX8220BT ?
Hello, I 'm interested by your project. Could you give me the reference of the part which is used as mask of color " Warm silver" ? that which makes the front of the Kenwood headunit. Could you also give me the name of the interface to preserve the orders at the wheel ?
What do you think about Kenwood DNX8220BT headunit ?
landsraad59
Re: Kenwood double din multimedia headunit in 308
Messagede Gentry » Jeu 28 Aoû 08 23:03
The Kenwood is at this moment I think the best all-in-one unit. Pioneer will come in march with the ne model of the HD3 double din unit and I think that will be a big competitor.
Although Kenwood has the CAW-PS1200 steeringwheelinterface which also connects the Kenwood with the multifunctional display, Pioneer has not that possibility as far as I know.
There is another trick to make it work properly needed, this I found out with a Peugeot engineer and we want to keep this ourselves for now. (sorry)
The frame around the Kenwood is from www.tomacarparts.nl
If you want I can sell a complete working set to you with full garantee, else you can buy the equipment and we can make it work properly, you can send me a PM
Gentry
Messagede seb66playa » Dim 31 Aoû 08 11:37
Super ce double din et l'intégration est vraiment nikel, par contre le site ne donne pas le prix du cadre ...
Messagede Gentry » Mar 02 Sep 08 08:24
Total system mounted with interface, antenna connector and mounting set € 1799 mounted in your car.
Mounting set advice price € 90
Gentry
Messagede seb66playa » Sam 06 Sep 08 08:04
Thanks for your answer, the price is hot !!! :?
Messagede topauto » Lun 29 Juin 09 00:18
Perso j'ai opté pour un fvpower.
Leur technicien m'a concocté une interface dédie pour la commande au volant.
j'attends de recevoir cela avec impatience.
J'espere que l'ordinateur de bord marchera apres retrait de l'autoradio d'origine.
Cout 550 euros avec gps, des que je l'ai monté je vous ferais une petite photo
topauto
Messagede SnorkY » Jeu 02 Juil 09 11:07
Curieux de voir le résultat oui...
SnorkY
Admin
Messagede chris2div » Ven 31 Juil 09 13:26
salut topauto,
des news ?
J'avoue que je suis intéressé par le même système, mais si je perds la config. de la voiture, ca n'est pas si intéressant que ca.
Merci de ton retour
chris2div
